View Full Version : bizhub c450 display in japanese language?
axyun
08-04-2017, 12:40 AM
Have customer with C450 with Japanese language in display. Saw procedure in user settings after pressing utility counter.
The problem is can't understand the japanese in order to select setting . Also customer cannot copy scan or print. the
machine does not respond. I appreciate your help very much. Frank/ActionPhotocopy
Woxner
08-04-2017, 02:15 AM
you will need too use a reset tool it mind is scrambled. probably power surge
JR2ALTA
08-04-2017, 03:11 AM
According to Google Translate "Select Language" in Japanese is
言語を選択する
allan
08-04-2017, 08:40 AM
ファックのマニュアルを読む
axyun
08-04-2017, 12:59 PM
What is a reset tool Woxner?
Hi Jr2Alta. Are you suggesting I google search the translation for each step in procedure. copy them and then go to customer and
hopefully i will see these same translations and be able to make correct selections? A little scary but might work. I think I would
prefer to tell customer I would be unable to help in this situation. Now if I knew a tech that knew Japanese that would be helpful.
emujo2
08-04-2017, 02:30 PM
The icons are in the same position no matter which language you select..System 1 is right above system 2 etc. If you can find a machine in the US market, just follow it as a guide. I don't have anything that old to ref, but system 1 should be the 3rd icon down/left side. Marketing area should be top choice in system 1, US is top row middle icon. Emujo
Woxner
08-05-2017, 02:44 AM
even if its japan it should respond with the buttons. but if nothing works you will most likely need this reset tool to reset nvram. then you can start over
copier tech
08-05-2017, 12:09 PM
There is an NVRAM initialize firmware that may help.
37277
axyun
08-05-2017, 09:09 PM
Thanks guys but I have decided to pass on this as too much risk for too little reward. Have left message with customer that I would not be able to help. If I knew a local very savvy Konica tech I would pay generously him to take care of it. Frank
copier tech
08-06-2017, 10:55 AM
That is a wise decision, these old boxes are not worth repairing, especially this C450, had many annoying issues, dumping developer was the worst!
