n25an
08-04-2017, 09:51 AM
I have been fighting with this finisher on a c258 for a while... started off with stapler problem... error 11-01
I took out finisher and took it appart...
fixed stapler unit grinding by reseating and running it a bit...
then had an issue where paper tray kept saying its full...
found that the sensor was stuck because plastic had popped out of place that positions the sensor that detects the exit tray full...
it worked... then rushed to put it together to leave
now getting an issue where the finisher had an internal error and the exit tray goes straight to the bottom and you hear a clacking noise as the gear on the left side gives the exit tray room to play...
I think I can fix this tomorrow by fiddling with the sensors on the sides that mess with tray height...
but being a newb to this finisher...
I am checking to see if there is anything that I have missed... any part you guys think I might need...
