Firmware update failure (a0p00y0-f000-g00-d1)
  • AhmedChamumi
    • May 2016
    • 119
    Hi,
    Im trying to update the above specified firmware up to no avail... What it does when you switch on the machine is to automatically updating is that normal? and after a few minutes it reports back that the Downloading is N.G. and if you try to just switch on the machine normally it simply get stuck at an hour glass...what should i do.
    Best of regards,
    Ahmed R. Chamumi.
  • habik
    • 2015
    Re: Firmware update failure (a0p00y0-f000-g00-d1)
    Originally posted by AhmedChamumi
    Hi,
    Best of regards,
    Ahmed R. Chamumi.
    Try different USB stick.
    Or format FAT 32 using win utility formatting tool rather then right-click and format.
    Firmwares HERE
    • AhmedChamumi
      • May 2016
      • 119
      Thank you i will do that and observe.
      Best of regards,
      Ahmed R. Chamumi.
