View Full Version : Taskalfa 300i black lines
ricmartinho
08-10-2017, 12:53 PM
Hi there!
I have this taksalfa 300i that's printing with black lines. I want to do Drum Refresh but this machine has MyQ and I can't enter Management Mode.
I'am able to enter Maintenance Mode but there is no option to do Drum Refresh.
Can anyone help?
Tonerkiller
08-10-2017, 01:27 PM
The drum refresh will not solve the issue. Print a counter page. Is the line there? Can you see any ware on the fuser?
ricmartinho
08-10-2017, 02:14 PM
The drum refresh will not solve the issue. Print a counter page. Is the line there? Can you see any ware on the fuser?The fuser is ok. The lines are faint, not solid lines. I'm guessing the charge grid as it is a little deformed. The cleaning blade seems to be doing it's job.
Enviado do meu ALE-L21 através de Tapatalk
The_Murph
08-10-2017, 03:42 PM
Are they fine, consistent width? Are they edge to edge or is there a blank edge on either side? If all answers are yes, you likely need a drum.
blackcat4866
08-10-2017, 04:32 PM
Samples? =^..^=
Has Been
08-10-2017, 11:21 PM
Hi there!
Can anyone help?
Try sanding down the mag roller with Scotch Brite
