View Full Version : Convert Biz C353 to a c253, hypothetically...
copyman
08-11-2017, 06:06 PM
Hypothetically, if you remove the MFP w/NVRAM, printer control, HDD, RAM & postage stamp size serial # board from a C253 and put them all into a C353 wouldn't the machine become a C253? I cannot think of what else would make the machine think otherwise. By the way only different part # between the two models is the MFP board. Looks like all other parts are same, of course the IU/toners are different because of the chips.
Probably wondering why I'm asking this. Long story, will explain later.
EarthKmTech
08-11-2017, 09:23 PM
fusing exit cooling wiring harness is different between 203/253 and 353 as the 353 has 3 fans and the 203/253 only has 2.
drive system wiring harness unique to ppm speed model. Why would they make 3 different versions of the same cable, perhaps this is one of the several secret ways the machine knows which version it is ?
fusing relay harness different between 353 & 253/203
copyman
08-11-2017, 09:42 PM
Thanks for the info. Shoots that theory to hell!
bechir00011
03-05-2018, 08:59 PM
sorry ,Mr ,i need minolta c253 firmware, i can buy it, thank you very much
Phil B.
03-06-2018, 02:42 PM
start your own thread ... piggy backing might not get you what you need.
