toner-end Magenta
  • harfan
    • Sep 2009
    • 9
    [Error Code] toner-end Magenta
    I have a Ineo+224e with a toner M problem,
    after 15 prints in only M color ,machine stops and comes with a toner-end,new bottle
    does not work?help please.
  • rrrohan
    • Sep 2011
    • 1977
    Re: toner-end Magenta
    but if it thinks you have no toner its normally because the sub toner hopper isnt being supplied toner from bottle and if you keep printing like you are you may end up with TCR error.
    Check toner bottle is rotating. mark it with a perm marker or somthing. if thats spinning your hopper may be buggered
    • jamesyboy
      toner monkey
      • Jul 2010
      • 188
      such errors are usually caused by the front bushing of the toner hoper getting bunged up : easy repair take off covers to reveal toner hopers clean end bushes , machines work ok if the bushing is removed , konica have upgraded the part due to these problems
      • harfan
        • Sep 2009
        • 9
        I put on new bushings ,that solved the problem.
