View Full Version : C452 fuser vs c451 fuser ?
mrfuser
08-15-2017, 06:46 PM
Does anyone know what the differences between the 452 and 451 for fusers they look identical ?
copier tech
08-15-2017, 08:33 PM
They look similar but are not interchangeable.
The C452/C552 have longer parts life & are a lot more reliable.
mrfuser
08-15-2017, 08:50 PM
So in a pinch you could use A c451 fuser?
copier tech
08-15-2017, 09:01 PM
No!
mrfuser
08-15-2017, 09:14 PM
so that's what I'm trying to get down to the bottom of here what is the difference between the two if anyone knows
Woxner
08-15-2017, 11:17 PM
i think the connectors are different. if it were the same then the part number would most likly be the same, someone has asked that here before
femaster
08-21-2017, 01:18 AM
I would assume at the very least, the connectors are wired differently. The C451 has a built-in fuse to reset the maintenance count, which the C452 does not. I'm sure there are more differences, but that is what I knows for sure.
mrfuser
09-19-2017, 05:32 PM
Do you know what the difference is between the c451 and c452 imaging units are?
thanks!
K
copier tech
09-19-2017, 07:05 PM
Different design, they wont physically fit.
Look at the C451 black it is a PCDU the C452 has a separate PCU & DV !
nassor
09-19-2017, 08:09 PM
Its different but u can use there parts, like opc drum, cleaning blade and developer powder.
copier tech
09-19-2017, 08:55 PM
Are we talking non OEM parts here?
If so then yes I would say the OPC drum cylinder etc is the same 🙄
