View Full Version : Biz C224e, DF-701 ADF issue when scanning
copyman
08-21-2017, 07:38 PM
Please see attached pic. This is the "dual scan" ADF not the DF-624 regular ADF.
Has lines on both sides only when scanning with ADF. Internal test pages and copies look fine.
When I first got there is was doing it on copies & scanning through ADF. I adjusted the horiz adj screw on the right hinge and copies looked fine. Had customer try scan and lines still there, a little better but still there.
Tried changing edge erase settings, etc. but didn't work.
Any help appreciated.
mo0651
08-21-2017, 08:19 PM
Do the ADF zoom adjustments. :cool:
copyman
08-21-2017, 08:25 PM
Thank you sir! I was thinking it looked either slightly zoomed in or out.
blackcat4866
08-22-2017, 12:26 AM
I think I would take it a step further: the full image adjustments:
Print ratio main-scan and sub-scan
Print centering main-scan and sub-scan
Scanner ratio main-scan and sub-scan
Scanner centering main-scan and sub-scan
Scanner voids
ADF ratio sub-scan
ADF centering main-scan and sub-scan
I usually find that none of those adjustments are perfect. and if you start at the wrong point you end up repeating the same adjustment ... repeatedly. =^..^=
SAR
08-22-2017, 04:47 PM
Try doing the mixed original size adjustment too. I remember a tech bulletin mentioning copies being shrunk if this adjustment was not done.
