View Full Version : konica C7000
MNS
08-28-2017, 02:11 PM
Hello Everyone.
Please i am using C7000 printer. Suddenly i got the error. (Error Code 3303). this Error is coming when i am sending job to print. and when i restart the printer the error will goes clear. What can cause of this error?
snoopyed
08-28-2017, 02:36 PM
Hello Everyone.
https://uploads.tapatalk-cdn.com/20170828/b0aa6d21ae77044ae555a82b3cd69a4d.png
從我的iPhone使用Tapatalk 發送
snoopyed
08-28-2017, 02:41 PM
Hello Everyone.
https://uploads.tapatalk-cdn.com/20170828/7c5c49c7c43c648fd07aa02fbb3cca88.png
Phil B.
08-28-2017, 03:01 PM
are you an End User? You can sometimes find a service manual on the web.. or go to the " Manual Request" forum here.
Woxner
08-28-2017, 06:22 PM
An error detection signal of
FM65 is detected
continuously for a
specified period of time
while the fusing cooling fan
(FM65) is ON.
• Conveyance drive board
(CDB)
• Fusing cooling fan
(FM65
methogod
08-29-2017, 01:35 AM
unplug cooling fan, see if it goes away. if so bad fan, pinched wires, loose harness wires - fine that harness in generals breaks from constant removal in my shops.
MNS
08-29-2017, 08:53 AM
Thanks everyone.
i removed the fusing unit and clean the fan and unplug and plug the connector again after fixing back printer started printing again. thanks alote for help. can someone help with me with manual. ii need a service manual.
thanks again
Phil B.
08-29-2017, 02:21 PM
Thanks everyone.
thanks again
you can try to google it or put in a request in the " Manual Request " forum.
