konica minolta c3850fs ce password reset
  • n25an
    • Jul 2008
    • 1030
    1. I changed a black drum on this model...
    then went to the service mode to print my reports after verifying all was well... it locked up on me... I entered 92729272
    that did not work... tried 9272927292729272 that did not work...
    so I wanted to reset ce and then disable it... no use putting another tech through this...
    another tech gave me this tip...
    1. Touch Menu
    2. Touch [Counter]
    3. Touch [Keypad]
    4. Press the following keys in this order: Stop > 0 > 9 > 3 > 1 > 7 (Nothing will happen on the screen)
    5. Wait 1 minutes before attempting the login again
    I was told one minute wait at the end and that did not work... so I did want any self respecting tech would do... go to the next service call...
    I did some research online and found that same solution on a muratec forum but with one change instead of 1 they say wait 5 minutes... so it would be something like this...
    later I did some research and found
    1. Touch Menu
    2. Touch [Counter]
    3. Touch [Keypad]
    5. Wait 5 minutes before attempting the login again
    3 questions...
    1. is this the correct way to reset the ce password on the 3850fs??
    2. is the ce password for the 3850fs 92729272??
    3. does anyone have a list of which machines are branded as muratecs but are really konicas???
    why you may ask... I found this answer on a muratec forum...
    Thanks for your help...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • selig67
    • May 2008
    • 156
    the relase lock is.......
    4.1.3 Procedure for releasing access lock
    1. Touch Menu.
    2. Touch [Counter].
    3. Touch [Keypad].
    4. Press the following keys in this order.
    Stop -> 0 -> 9 -> 3 -> 1 -> 7
    (With this procedure, activate the access lock release timer to start timing.)
    5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released
    • n25an
      • Jul 2008
      • 1030
      Re: konica minolta c3850fs ce password reset
      bless you...
      I go back to machine tomorrow....
      pray for me...
      I might kick the ....
      this is a family forum...
      you get the idea...
      1. Touch Menu.
      2. Touch [Counter].
      3. Touch [Keypad].
      • mjunkaged
        • 379
        Originally posted by n25an
        bless you...
        pray for me...
        you get the idea...
        Be advised the access lock timeout can be set to UP TO 60 minutes on most models!! Lunch break??
        So if 5 don't work.......
        • n25an
          • Jul 2008
          • 1030
          LOL...
