View Full Version : Jamming BhC654e doc feeder (DF-702) Jam code C6633
rbalanjr
09-07-2017, 02:26 AM
Hi. Has anybody encountered this jam code on the doc feeder of a BHC654e? I cleaned all rollers and did the adf adjustment feed and zoom adjustment and still getting a jam after the 4th page. It is all wrinkled inside the doc feeder when I take off the paper jam. Sometimes the code is C6653. Any help or suggestions?
Woxner
09-07-2017, 03:59 AM
both codes say the same thing
Code: 66-53These are the only recommended paper sizes for 1-Sided Originals/2-Sided Originals/Mixed Originals.
5.5x8.5
8.5x11
8.5x11R
8.5x14
11x17
These are the paper weight specifications for originals being fed from the document feeder.
1-Sided Thin Paper (9.25 lb. to 13.063 lb.)
1-Sided Plain Paper (13.25 lb. to 55.75 lb.)
2-Sided Plain Paper (13.25 lb. to 55.75 lb.)
Mixed Original Plain Paper (13.5 lb. to 34 lb
how are the rollers. also one way bearing
rbalanjr
09-14-2017, 11:21 PM
I replaced the paper feed motor and had to modify the conveyance clear mylar as it has a nick and it is hitting the paper and causing it to jam. I have to pile it a little bit to make it smoother. Problem solved. Thanks.;):)
copyman
09-14-2017, 11:27 PM
I was going to post to look at the mylars inside the feed in area. I have replaced several sets of all the different mylars. They corrected this issue on the DF-701
