View Full Version : Miscellaneous C451 Pico Fuse Location
MFPs R Now PCs
09-07-2017, 03:20 PM
We have a bizhub C451 fuser that we are trying to locate the reset pico fuse on the fuser/fixing unit. I swear it was on the end, however we seem to have all of the covers off and cannot locate it. Does anyone have some specific information for location or a picture by chance? Thanks in advance, I.T. guy back in Copier division
Synthohol
09-07-2017, 04:54 PM
Side cover in a black rubber tube likely with zip ties is the green .063A fuse.
copier tech
09-07-2017, 07:12 PM
If you install the life stop fw you dont need to worry about replacing the fuse on the transfer & fuser units.
Brett GS
09-07-2017, 07:14 PM
Under the cover the same side as the plug/connector its zipped tied,it is under a clear tube.
