View Full Version : CQ C554 skewing
copycart
09-11-2017, 04:14 PM
Copier is skewing when making copies from the Document feeder and glass, but internal prints are not skewed
Azharuddin
09-11-2017, 04:15 PM
Just adjust the ADF on the right side hinge . There will be a adjustable screws .
Sent from my XT1562 using Tapatalk
copycart
09-11-2017, 05:07 PM
I can see that if it was an ADF skew only but if I lay it on the glass I also get skew from all paper trays
blackcat4866
09-11-2017, 06:11 PM
Most likely the scanner frame had been bent by leaning on the corner. =^..^=
rrrohan
09-12-2017, 03:50 AM
Grab the front left corner of scanner and give it a few upward jerks. Otherwise adj scanner position wgere it sits on wire. Youll only want to move it like 1mm or so.
I try to see if it swuare by lining it up to a straight edge on the frame.
I find its normaly when there is a shelf above copier. They lean on copier of rest boxes on adf but have had a few at runup too so yeah
copycart
09-12-2017, 01:19 PM
Pulling up on the scanner did the trick, Thanks
