View Full Version : TA221 J11
blackdog
09-11-2017, 06:12 PM
Hey you Kyocera Aces,
Got a TA221 giving a J11 Jam code from cassette 1.
I installed new feed/sep rollers, clutch is working fine.
Swapped out cassettes and still N/G.
What bugs me is sep roller is turning but no feed?
Any suggestions would be greatly appreciated.
blackcat4866
09-11-2017, 06:22 PM
Is the separation roller flopping around because, maybe, the plastic post that it swivels on is busted off? =^..^=
blackdog
09-11-2017, 10:12 PM
Hey thanks Blackcat for your reply. Hope all is well on your end.
I replaced sep and feed rollers this morning and all corresponding parts looked to be intact.
If I could take a stab it I would say Feeder roller is not coming in contact with paper?
I would assume the clutch is turning the shaft and all rollers than paper should feed?
Is feeder roller stationary or does it drop down to meet paper at some time?
I don't see any signs of feeder roller coming in contact and moving paper at all.
blackcat4866
09-12-2017, 12:17 AM
The pickup roller is spring loaded, but it's the spring loaded lift plate that lifts the paper up to the the roller. It's generally a pretty crappy feed system. IIRC the spring clutches will wrap if a paper jam isn't removed correctly. If you remove the rear cover, you can make a Sharpie mark on the end of the feed shaft, then watch to see if it rotates. My bet is that it isn't, and you need a clutch. =^..^=
