View Full Version : SOLVED: colored line from ADF C3351
giddyupngo
09-14-2017, 07:32 PM
I was getting a yellow line when I copied an original through the DP/ADF, but nothing when copying in B/W thru ADF, and nothing from glass.
I ended up taking it apart, and finding black ink marks on the UNDERSIDE of the slit glass, on the opposite side of where I thought it would be. There was also an ink spot on either end of the white reference. This is a brand new machine, so there may be some type of mark they make during inspection. I cleaned all the marks off, just to make sure. I realized later that this machine prints out images upside down, or 180 degrees from the way you feed it. Keep that in mind when examining slit glass. Hope this helps someone.
Sent from my SAMSUNG-SM-G930A using Tapatalk
