View Full Version : Error Code c-c135 error code
zubinn
09-15-2017, 02:54 PM
37635
has anyone seen this error code before c-c135 it is on a km c7000 made in 2011 machine.
i cant find this error code in any of the manuals.
Synthohol
09-15-2017, 04:35 PM
Did you actually LOOK in a manual?
Page K-296 HDD/P connection abnormality.
zubinn
09-16-2017, 02:19 AM
37653
can you share your page k-296, the manual have is up to c-c120
zubinn
09-16-2017, 02:51 AM
do we have the same manual ? i did not manage to find the error code c-c135 in the entire manual.
page k-296 on the manual ... top of the page
C-D0E3
Classification
Main body: HDD/Y read/write abnormality
K -296
laitang
09-16-2017, 11:09 AM
Your service manual is old version,
the lattest is 4.11:
modified:
K.2.3 Malfunction code list
Correction of error about C-0415, C-0416, C-0417, C-0418
Addition of C-C135, C-D010
date: 2014/01/21
Code
C-C135
Classification
Main body: HDD/P connection abnormality
Cause
HDD/P unconnected
Measures to take when alert occurs
The main body stops immediately to turn OFF the main relay (RL1).
Estimated abnormal parts
• HDD/P (HDD/P)
Correction
Turn OFF/ON the sub power switch of the main body.
Note
• The message "Please call service" is displayed on the panel.
Solution
1. When HDD/P is not used, check the setting of the software DIPSW 2-1 on the service mode and when the setting is configured to "1",
change to "0".
2. Check the connector connection and the wiring between HDD/P and MCB/P, and repair it if any abnormality.(Wiring diagram: Main
body (2/3-2):19-G)
Faulty part isolation DIPSW
DIPSW18-7
Control while detached
HDD unusable (HDD not connected)
However, it cannot be detached when the scanner or the IC-601 is connected.
zubinn
09-16-2017, 01:02 PM
thanks for pointing us in the right direction.
wiring is fine. however what has fixed it was
i/o. 99-03. disk check. ran it twice and now it boots.
I wonder how long these drives are going to last before they die for good considering the machine is from 2011 and drives typically last 3 to 5 years.
