View Full Version : IC-601 Job Centro error
Texers
09-16-2017, 11:35 AM
37656
hi all,
i have IC-601 with a BH c6000.
when i try to edit job in the image controller hold, there is this "application error" coming up (see image att).
i have reinstalled job centro, still same error. anything else seems to work fine.
anyone can help?
thanks!
Synthohol
09-16-2017, 12:18 PM
is it the latest job centro?
may not be compatible.
Compatible Devices for use with Job Centro 2.0:
IC-604 (AccurioPress C6100/ C6085)
IC-603 (AccurioPress C2070/ C2070P/ C2060, AccurioPrint C2060L)
IC-602 (bizhub PRESS C2070/ C2070P/ C2060/ C1100/ C1085/ C1070/ C1070P/ C71hc/ C1060, PRO C1060L), PRO1100 controller
Please use Job Centro Ver. 1.0.05000 for IC-601 bizhub C6000/C7000/C8000
Texers
09-16-2017, 12:31 PM
job centro 1.0 v1.0.035.. i know its not the latest.. but this worked before..
it is quite weird.. everything works apart of Job Edit button..
i would presume if it would be incompatible.. then i should have other issues as well..
Synthohol
09-16-2017, 02:09 PM
that's all that i saw even slightly relevant to your query on the KB.
*had fingers crossed*
is there an application log you can look at?
the 7000s i service all have Fierys so i never used centro.
sorry.
Texers
09-17-2017, 09:48 AM
sorry.
Yes, i have only 2.. this one.. and an IC602 that can find the printer in the initial set-up and then cant connect to it..
Pretty reliable controller... :/
