View Full Version : How to print on NCR paper on Accuriopress 2060
topimpress
09-16-2017, 03:26 PM
Hi,
i want to print a NCR booket with 2 color. how can i setup the printer to print 1 document on two NCR paper with different color. white color on tray1, yellow color on tray 2...
thx
Synthohol
09-16-2017, 05:44 PM
why not just get the 2 part yellow and white NCR paper and use the same tray and set the controller to print 2 copies of each page it receives.
i have 2 accounts doing this.
https://r3---sn-ab5l6n67.googlevideo.com/videoplayback?requiressl=yes&ip=2a01:7e01::f03c:91ff:feb3:d3fc&key=cms1&gir=yes&mime=video/mp4&itag=18&signature=6AEAE654DE1E83E722D484059A5CDCD484504D67 .369A04AAA96C023B6BAA40376AD22D1E58D0DD69&sparams=clen,dur,ei,expire,gir,id,initcwndbps,ip,i pbits,ipbypass,itag,lmt,mime,mip,mm,mn,ms,mv,pcm2, pl,ratebypass,requiressl,source&source=youtube&pl=20&ipbits=0&ei=q1S9WY3eDoWEc_CGnNAN&expire=1505601803&id=o-AFza619cqUOvrEi6BtMQULr0iVIxXJdWWcJqwGARL21b&clen=2257917&pcm2=no&lmt=1487868961944982&dur=34.388&ratebypass=yes&title=Ncr+AccurioPress+C2060.mp4&req_id=88e7fa9961da36e2&ipbypass=yes&mip=108.50.236.212&redirect_counter=2&cm2rm=sn-8xgp1vo-xfgel7s&cms_redirect=yes&mm=30&mn=sn-ab5l6n67&ms=nxu&mt=1505580083&mv=m
also depending on the software you may be able to pick from multiple trays depending on the queues set to default to certain trays.
i had a MAS90 setup a while ago and set 3 queues to diff trays and in MAS90 i was able to select all 3 for the 3 part NCR form.
methogod
09-17-2017, 01:42 AM
same way you did it on any other fiery, media set, pg1 tray 1, pg2 tray 2....send x number of copies.
but Synthohol (http://www.copytechnet.com/forums/members/synthohol.html) is correct, best to buy pre-collated NCR, unless its a custom run or specialty stuff....
Synthohol
09-17-2017, 02:34 AM
the only reason i like the pre collated sheets is if there is a registration difference from tray to tray (common) i know all the image/text will line up coming from the same tray.
methogod
09-17-2017, 10:54 AM
yes, unless your running some weird stack.. that is not available as a pre collated set.
