View Full Version : Konica C5501 - Error C-C101
linkble
09-20-2017, 06:35 PM
Hello everyone,
First sorry for my english, i'm french.
After mounting a new drum and lauching my konica c5501 i got a C-C101 error code.
I checked a few post on copytechnet and found that i "destroyed" this small wire (photo) (and maybe the PRCB).
37681
Can someone please tell me what is the name or part number to buy a replacement, i searched everywhere but cannot find nothing about this particular wire...
It would be really helpful since it's my only machine and cannot afford another one...
Thank in advance.
Synthohol
09-20-2017, 09:15 PM
solder and heat shrink tubing.
cheap fix.
linkble
09-20-2017, 09:28 PM
cheap fix.
Tried to fix the wire but still having the c-c101 error code, i really dont know what to do...
Synthohol
09-20-2017, 09:57 PM
C-C101
When the sub power switch
(SW2) is ON, no response is
received from the printer control
board (PRCB) within the speci
fied time.
Printer control board (PRCB)
I/F board (IFB)
Image memory control board
(IMCB)
Overall control board (OACB
may have popped an ICP fuse on the printer control board.
linkble
09-20-2017, 10:19 PM
C-C101
fied time.
I/F board (IFB)
(IMCB)
Does that mean i need to change the prcb or is it possible to change only a fuse ? And thanks for helping me !
linkble
09-21-2017, 08:33 AM
If it can make it clearer i made a few more detailled photos, thank you in advance for helping.
37689376903769137688
Synthohol
09-21-2017, 02:09 PM
When I get a chance I'll see if I can dig up the ICP fuse list I have somewhere.
If your soldering skills are really good you can solder in an in line fuse but if not and you don't have a magnifying glass then it may be better to change the board.
Lemme get a couple service calls done and I'll look for the chart and you can test the ICP with an ohm meter.
Synthohol
09-21-2017, 10:49 PM
this should help...
linkble
09-22-2017, 08:16 AM
this should help...
WOW thank you Synthohol this really helps, i'm going to test the ICP23 tomorrow but i dont know how to check the connectors seen in red on your pdf is it also with an ohm meter?
Do you have in memory the name of the cable that i destroyed, i searched everywhere but cannot find it...
Will get you updated with the fuse tomorrow, thank you.
