maksima
09-21-2017, 07:11 PM
Hello Guys, I have a sick printer that after being transported from one place to another greeted me with C2253 error. :(:( The printer worked perfectly fine before, although it did get hit in the rear while being transported in the van. Plastic on the top part of the printer cracked and the air duct plastic broke off. I have tried the usual, re-seating all the cartridges and imaging drums, re-seating all the trays. Everything seems to be intact, but no idea there to go next :confused: Couldn't find a service manual online anywhere, which would probably help a lot.
This is what i found online regarding this error:
Code: C2253
Description:
PC motor’s failure to turn
The motor lock signal remains HIGH for a predetermined continuous period of time while the motor is turning.
Remedy:
1 Check the connector between M2-PRCB CN31 for proper connection and correct as necessary. 2 Check the M2 connector for proper drive coupling and correct as necessary. 3 M2 operation check PRCB CN31-9 (REM) PRCB CN31-12 (LOCK) 4 Replace M2. 5 Replace PRCB.
Checked the PRCB and the CN31 connector is plugged in all the way. Re-seated it anyway, the problem still there. Haven't dug deeper yet.
Any suggestions on what else to try? Thank you!
Code: C2253
Description:
Remedy:
