View Full Version : Bizhub C450 pausing between prints
goose
08-28-2008, 03:53 PM
999 prints of a one page document, the copier will print maybe 2 pages, pause for a while, print 5 pages, pause for a while, print a few more and so on making the job take far longer than it should.
Any ideas?
Haroldbfix
08-28-2008, 09:13 PM
Any ideas?
Try updating firmware and using a different driver. PCL would be good.
goose
08-28-2008, 11:00 PM
They're already using a PCL driver, but there is a later one available. They are getting a new PC new week, so I assume that will have Vista, which will necessitate a driver update anyway.
Thanks for the reply.
strider5555
08-30-2008, 10:32 PM
Is the machine receiving the print job 999 times? If so, uncheck the collate check box on the print driver. Also are you using the standard controller, or the fiery. Using the wrong driver may cause similar problems.
mtech
08-31-2008, 05:10 AM
Is this occurring from more than one paper tray? I have seen some Sharp Imager series do this when there is a flat spot on the reverse roller. If it is only one tray with the issue then try replacing the feed tires.
