907tec
10-06-2017, 01:01 AM
Have a C284e with only 100k giving me problems. Main issue is that the density is uneven from front to back. See attached scans. Light density patterns (30) for Cyan and Magenta attached, showing that front and rear of machine are lighter than the middle. Issue occurs with all colors, but more obvious on cyan/magenta. Second issue, likely related, is that test patterns containing maximum density K patches show "fuzz". See the attached printer demo page. D-Max boxes have a sort of "halo" around them, almost as though drum's charge is leaking out.
None of the consumables are over-life.
Have already tried:
Drums (New K drum still installed, tested with CMY drums from known-working machine)
Dev Units (CMYK dev units tested from known-working machine)
Transfer Belt (still has the new one installed)
2nd Transfer (still has the new one installed)
Cleaned laser windows (repeatedly)
Cleaned IDC sensors and checked cover actuation
HV Unit (and checked contacts/springs for signs of damage/arcing)
PRCB Unit (sounds weird, but suggested by service manual)
Frimwar
After each part was installed, I ran gradation adjusts and eventually init+stab's. Level History / Tables does not show abnormally high VDC/VG values for any color. IDC/ATDC/ATVC values all look normal.
Waiting for a repaired MFPB from Hytec right now, thinking about swapping PH from another machine in the meantime.
Anyone ever experience something like this?
3781137812
Have already tried:
Frimwar
3781137812
