tonerjockey
10-10-2017, 07:05 PM
Hi Guys, me again. just hoping for any ideas that might help. this machine would stop when using the bottom drawer # 4, when the paper was at the first vertical transport section roller, after trying to leave the drawer. (as it did for drawer # 1.) drawer # 1, i replaced the pick up, feed rollers and the separation roller assy. drawer 1 was fixed. the lower right cover was always popping open by itself. i replaced the 2 lower cover latches and the paper feed roller set as i did to drawer # 1. the door stays closed now, but it still stops most of the time at the first rollers in the lower vertical transport. sometimes one will feed, but then jams. i tried to swap out the feeders with drawer 3, but of coarse, that one has one large wiring harness plug jack, while # 4 has two. i tried cleaning all the vertical transport rollers, holding the door fully closed, cheated the interlock on the lower right door and the rollers turn solid. the sensors are the photo LED, and are clean. e-gads Batman, what in the world? anyway, it was getting late, so i didn't look to see if i could swap the # 4 feeder with # 2 or even 1. those require the right side door to come back off.
which would bring me to another quandary. this and another C353 (don't know if i did it?), after i had been in there, the bypass tray raises and lowers at just the wrong time and paper wont feed. there are two similar 2 pin plugs of the 3, that are from the bypass drive when you remove the door. one is blue, the other white.i tried on both swapping them, and i then got error codes. so reversed them and no code, and no feed. but both customers told me that they never use them, so who knows.
i am not sure if this is a sensor or roller issue. i had sprayed the one way clutches on the paper feed roller shafts, and even pulled the feeder to check that they were working.
if anyone has any ideas, i would really appreciate it once again. thank you very much, Jim
