bizhub 250
  • joetennisjoe
    • Aug 2008
    • 16
    bizhub 250
    Does anybody have the procedure step for drum, starter, and resetting the drum count on this copier?
  • redime
    Go into Tech Rep mode
    Counter
    Special Parts Counter
    Clear Drum / Developer
    Power Off
    Replace Drum and Developer
    Power back on
    Go back into Tech Rep mode
    Functions
    F8
    Drum and DV must both be replaced at the same time. If you go into SW Switches, and do switch 418 and change the HEX number to 50 you can turn off the "PC Drum" message.
    • ni311
      • May 2008
      • 658
      Is it possible to eliminate the drum message for DI2510 using the softswitch?
      Konica Minolta Error Codes - Explanations and Solutions
      • redime
        Should be the same, but double check before you do it ... remember what your old HEX number is. You can do it with the binary as well, but its much easier to remember the HEX number as 50. I cant recall what it starts out as - out of the box, I want to say 55 or 58 or something.
        • ni311
          • May 2008
          • 658
          Thanks a lot, I'll give it a try next week and let you know.
          • needlesgxe
            • Aug 2008
            • 30
            dont for get to reset ur PCU (Drum) life counter
            • redime
              Dont ever just reset your drum life counter, you will end up with error codes. Drum and DV need to be done at the same time. If someone scratches a drum, with new DV.... just pop the new drum on WITHOUT resetting the count.
              I just changed a drum on a 350 that went 203% of life, drum units last a long time so long as they are cared for.
              Also, when changing DV - its important on the DV unit you will see two screws holding down a metal plate, it will have mylars on it that attatch it to the drum. Take these screws out and very carefully set the metal plate out of the way. basically, flip it over and it should rest nicely just past the Mag Roller -- you will expose old developer. You will want to vac this out as well when doing a DV change, NOT just whats accessible from removing the plastic cover. This will help ensure you get good quality for a longer period - as you now have all new DV in there, it will also prevent problems down the road with the DV unit binding up because you just dumped a whole bag of DV into a DV unit with 1/3 of the DV still in there - its too much.
              • facatoros
                • Aug 2008
                • 15
                bide bunu dene
                2510 larda drum kiti dışardayken o ayarları sıfırlayacaksın.
