C350 impossible to reset
  • ni311
    • May 2008
    • 658
    Hello guys,
    I cannot reset a belt and fusing unit from a C350 machine. First, I tried with several fuses between 50 to 80 mA, after this I tried with a Konica Minolta transfer kit and fusing unit. The result is the same, call your tech rep.....
    First I was thinking on a bad contact, but it seems strange to have the same problem with both units. Now I'm thinking on a board malfunction.
    Was anyone in the same situation?
    Thanks in advanced for your answers.
    Konica Minolta Error Codes - Explanations and Solutions
  • strider5555
    • Jun 2008
    • 96
    Are you getting a "Malfuction Detected" C-xxxx code? If so, you will have to first reset the error code, at which point the machine will go through its stabilization process and eventually reset the counts of these units.
    • ni311
      • May 2008
      • 658
      Nope, no malfunction codes. Just " you need to replace... call your tech rep..."
      I tried to reset the machine with no improvement.
      • redime
        Have you gone into tech rep, counter and cleared your fuser count?
        • ni311
          • May 2008
          • 658
          You cannot clear the fuser and transfer belt counter. You can clear the counter for transfer roller and ozone filter, from what I know, but this doesn't help.
          • JSC
            Gimp
            • Dec 2006
            • 618
            I have never had a problem fusing transfer belts or fsr units, but i have had a very similer fault when trying to reset image units on C350's, after chipping the units would not reset and the life counter stayed the same, the only way around it was to 'pull' the power cord from the rear of the copier while the power was still on then switch off the copier plug the power cord back in and power up the copier..................might be worth a try?
            The gene pool could use a little chlorine.
            • Haroldbfix
              • 212
              Hello guys,
              Any updates on this issue?
              • ni311
                • May 2008
                • 658
                Turned out to be the PWB-MC. After replacing it, it worked just fine.
                • Haroldbfix
                  • 212
                  Thanks for the feedback, I keep that tip in mind.
                  • RockETop
                    Curmudgeon at large
                    • Apr 2007
                    • 171
                    P-XX codes will prevent IU's and such front resetting too.
