ArtPetrovich
10-15-2017, 08:57 PM
After trying setting the parameters to use SimWin:
Turn on the printer
2. Press Menu/select key
3. Press the key to select “service mode”
4. Press Menu/Select key
5. Insert the password (92729272) and press the Menu/Select key.
6. Select “System Settings” and press the Menu/Select key.
7. Press the key to select “SoftwareSWSetting” and press the Menu/Select key.
8. Select Software-SW “62” and press the Menu/Select key.
9. Press the key to select “Set by Hex”.
10. Change the setting from “00” to “01” and press the Menu/Select key, the printer display shows
“please wait” after the display has returned to the menu, this can take up to several minutes, press
the cancel key.
11. Turn off the printer
Upon further turning the printer on on the screen appears an hourglass.
When trying to do a Trouble reset (when switching on hold the Central button) on the screen above right appears a black point.
As I understand it, I need to sew the NVRAM? There is Compact Flash 256mb, but I have not the firmware and the instructions for the firmware.
Please help in the restoration of the machine, thanks in advance.
3787337874
Turn on the printer
the cancel key.
3787337874
