View Full Version : Konica c35 dash marks
Konica c35 has dash marks 1 inch wide down last side. Don't see marks on drum. Also get c-6790 code every now and then. If not drum what could cause dash marks. Thanks
habik
10-20-2017, 05:03 PM
Konica c35 has dash marks 1 inch wide down last side. Don't see marks on drum. Also get c-6790 code every now and then. If not drum what could cause dash marks. ThanksDev. Clean or replace if over life. Comes as IU.
Samples help too!
Sent from my Mi A1 using Tapatalk
tech51
10-20-2017, 05:36 PM
Check your transfer belt. I had one recently with a series of small squares on the prints. I was thinking it was the mfp board as it looked like a generated image, however it turned out to be the transfer belt not cleaning because it was blocked up. I cleaned out the waste area and the fault went away.
