View Full Version : bizhub 654e drum rest
maj143
10-28-2017, 10:20 AM
hi all
please i have bizhub 654e i want to rest the drum unit can any tech help me with that
thanks alot:):confused:
copier addict
10-28-2017, 11:22 AM
hi all
What do you mean when you say you want to "rest" the drum?
maj143
10-28-2017, 01:02 PM
Hi
I mean i want to clear the drum unit error without change the drum unit
I think there is way to do that any help
habik
10-28-2017, 01:10 PM
You want to reset the life or image quality problem
Sent from my Mi A1 using Tapatalk
maj143
10-28-2017, 02:00 PM
Yes i want to reset the life
The copier not working show change the drum unit
insigniawales
10-28-2017, 02:55 PM
It is not possible to reset the IU life through the machine. The consumable resets the counter.
Sent from my SM-G903F using Tapatalk
Woxner
10-28-2017, 03:46 PM
the drum warning can be turned off in service mode to never stop
EarthKmTech
10-29-2017, 01:09 AM
from memory the "chip" on the drum is 3 pins, between 2 are a resistor (type identification & installed detection) and between other 2 pins is a very light duty fuse, blown when counter is reset and new to be detected as new. They are smd and very small and fidly to replace.
I have jury rigged a pico fuse between the appropriate pins as required in an emergency to get a blown new toner cart level reset etc.
