View Full Version : Miscellaneous Searchable PDF file in Konica Minolta C654e
musthafavi
11-13-2017, 10:12 AM
How to enable or activate Searchable PDF file scanning option in Konica Minolta C654e
copier tech
11-13-2017, 10:31 AM
License Kit LK-105 v3 Searchable PDF - i-Option - Solution Software | KONICA MINOLTA (https://www.biz.konicaminolta.com/solutions/i_option/lk_105_v3.html)
musthafavi
11-13-2017, 10:59 AM
could you please provide download link and installations steps
emujo2
11-13-2017, 01:30 PM
There is no "download" link. Option must be purchased through KM. It is only a token code to enable a feature already built in to the software. You also need the additional 2 gb RAM. To install, simply enter service mode/ billing settings. Enter the token code and if the MFP has an internet connection it will contact the KM LMS sever and install the option. If the MFP does not have an internet connection then you must license manually via LMS. Be advised, using this option for heavy scanning will bog down the MFP and result in much slower overall performance. Plus the conversion process is not even close to a true OCR engine like ABBY or Omni Page. Emujo
