View Full Version : Blurring Black Lines On Printed Paper After Copying Large Quantity Problem.
Omar Faris
11-15-2017, 01:00 PM
Copier model: KONICA MINOLTA BIZHUB 350.
Status: works well without any problem and the printed paper is clear and good.
Problem : some black lines begin to appear gradually, after copying a large quantity such as more than 250 pages, the more i continue copying the more the black lines become clearer.
Exception : if the machine is not used for about an hour after the problem above, the printed papers becomes again good quality, for copying normal quantity.
Question: why these black lines appear only after large quantity of continuous copying, what causes this problem?
Thanks.
mo0651
11-15-2017, 01:52 PM
How old is drum and dev. Looks like a grounding issue, or residual charge on the drum.
habik
Charger, worn drum & blade, calibrations.
Sent from my Mi A1 using Tapatalk
Zesti
11-15-2017, 01:59 PM
What count on Drum?
Simply put in new drum, Developer kit and reset the counters and F8.
Omar Faris
11-15-2017, 03:17 PM
What count on Drum?
Thank you guys,
The Drum counter is 214 %, maybe it needs a new drum, it's just that i don't understand why this problem comes out only after large quantity of continues copying, i was hesitant is it a problem of drum or something else.
thank you again all of you.
mo0651
11-15-2017, 06:10 PM
160k over PM. Hmmmm. I wonder where to start??:confused:
