View Full Version : Konica 8050 page skewing,, help Please
Garrett1025
09-04-2008, 09:56 PM
Every page from every trey, including bypass and lct is scewed. Anyone know how to fix this?
Gergő
09-04-2008, 10:04 PM
From document feeder or from pinting?
Garrett1025
09-04-2008, 10:07 PM
Printing and flatbed coping
laserman06
09-05-2008, 12:01 AM
Pull out your ADU, on the right side(to the right and below the bypass rollers, you will see the entrance baffle. This upper baffle gets bent and causes skewing. If you reform it, it should straighten out your copies. If it is too bad, then you will have to replace it.
HTH,
Rob
Garrett1025
09-05-2008, 08:26 PM
Is there a way to adjust this in the settings (36 mode) or anywhere? I had a service man look at it and he was able to adjust some of it out, but not all. Instead of calling him back, if I can do it my self. It takes about 7-10 days to get him here.
Garrett1025
09-06-2008, 03:41 AM
** Bump **
Need help in a bad way.
laserman06
09-06-2008, 04:20 AM
Did you check the baffle that I talked about. I have seen it quite a few times, be the culprit for skewing. If you look at it closely you will see that the gap between the top and bottom is not even.
And I do not know of any skew adjustment in 36 Mode. Only thing that you might try is to increase the registration loop. That might give it more of a chance to straighten out. But if you go to far then other problems will occur.
Haroldbfix
09-08-2008, 05:19 AM
There is a mechanical skew adjustment that is just before the lower transfer roller.
