View Full Version : Bizhub 654e
antone
12-01-2017, 06:25 PM
Jams when duplexing ...jam code J30-03 ...any 411
Sent from my SM-N920V using Tapatalk
habik
12-01-2017, 07:34 PM
Flag out of position in branch section? Or bent photointerrupter holder. Sticky gate.
Eject rollers seizing up? (Slow reverse)
Reg actuator worn ( short timing/loop on plain duplex).
Dust removers full of paper dust / reflective sensor soiled.
Which tray is it doing it with mostly?
Sent from my Mi A1 using Tapatalk
Synthohol
12-01-2017, 08:18 PM
there is a little rubber/foam silencer pad on the left side of where the duplex gate contacts.
i have seen this pad cause jamming from the gate either getting stuck in the wrong position or when it swells from heat it wont allow the gate to open all the way.
i scrape it off with my nail and it will click louder during duplex but jams are gone.
Phil B.
12-01-2017, 08:43 PM
replace foam pad with some E Tape... just like you would an HP Plate Solenoid be sure to clean the gate that connects to pad with IPA
