View Full Version : Whining noise from machine and failure to work
Capodastra
12-01-2017, 10:31 PM
Hi,
My C451 was printing ok, the a repetitive clicking noise and finally a continuous whining noise like something was jammed.
now it wont work and just makes the whining noise when i switch it on.
Any ideas . . . please.
Barney
rrrohan
12-02-2017, 12:10 AM
Hi,
Barney
Wont work? What does it jam or something
copyman
12-02-2017, 04:14 AM
Any trouble codes on display. You need to be a little more specific if you want help. There are a lot of good tech's on this forum but not many mind readers:cool:
Zesti
12-02-2017, 10:27 AM
The typical fault of C451 is transfer belt cleaning unit gear and motor shaft. Check cleaning unit for overload.
Capodastra
12-03-2017, 09:32 PM
Zesti, I do believe you are correct.
I was finally able to contact a colleague who was a Konica engineer and now works for Zerox.
He has looked at the machine and determined it to be the transfer unit which is jamming. He has checked the cleaning unit and it seems it cannot move the transfer belt one way even after emptying the waste toner.
I have ordered another unit (via internet) and am waiting for delivery.
Thanks for all help.
Barney
Capodastra
12-06-2017, 05:36 PM
So the transfer unit has arrived and replaced but the whining is still there. BD((
Seems there are a couple more parts still needed.
Bit frustrating when the internet firm whom I tried purchasing it from took my money then told me they were out of stock and after contacting THEIR suppliers were told it would be at least a week and the price would have to be £100 more!!! Needles to say I asked for my money back and finally got one from Ebay at nearly half he price. It is a compatible not original (same kind as the firm who did not have one in stock).
So my colleague (Ex Konica guy) is trying to get the parts I need . . . .
This is sooo frustrating . . . . and putting me way behind with work - but I guess that is what this business is like!
Thanks again to Zesti for your advice too.
907tec
12-06-2017, 08:26 PM
Unfortunately, if the transfer cleaning mechanism is indeed your problem, you have ordered the wrong parts. The cleaning motor and associated gearing are located on the machine main body, not the Transfer Unit. You have to take off the main power supply on the back of the machine, the cleaning mechanism is located behind that.
Zesti
12-07-2017, 09:16 AM
907tec is right. It's cleaning unit not the transfer unit and there are no compatible parts ALL WILL BE ORIGINAL, ether new or pulled from machine. A modification was made in the cleaning unit drive section. Check the cleaning motor shaft and associated larger gear for wearing.
