View Full Version : Bizhub 552
antone
12-06-2017, 05:39 PM
Jams tray 2 only J2002 feeds 4 inches stops any 411 out there!
Sent from my SM-N920V using Tapatalk
Flash
12-06-2017, 10:41 PM
Try the paper feed clutch.
antone
12-06-2017, 11:20 PM
Try the paper feed clutch.Will do
Woxner
12-07-2017, 03:57 AM
have you changeed the feed rollers and oneway clutches
antone
12-07-2017, 08:57 PM
have you changeed the feed rollers and oneway clutchesYes all new,even vertical gear....what motor only runs tray 2
tech51
12-07-2017, 09:38 PM
Been a while since I've worked on one of these but I seem to remember that the locking lever on the lower right hand door could break causing a lack of pressure on the conveyance rollers. Might be worth checking that the catches and hinges are all in place....
allan
12-08-2017, 03:53 AM
Jip i will second the door hook being the problem.
