View Full Version : c350 print connect
james
09-06-2008, 09:59 PM
I am trying to set up a c350 to print for the first time. I loaded the driver, but unlike 70 series the port must not be 10001. I am having alot of trouble with this one. Can anyone walk me through each step?
knightfall
09-06-2008, 11:21 PM
What type of network and OS are you using a printserver or direct print? what print controller?
cobiray
09-06-2008, 11:31 PM
If you have the Fiery Controller (IC-402 I think) then the port must be configured properly based on which queue you want to print to.
james
09-06-2008, 11:35 PM
Direst print. I think I solved the problem. I checked LPR and entered print. It printed a test page. Still working on scan. Thanks for your help. I've worked on konica in Orlando since the 1803's. Not great with computers, getting better all the time.
cobiray
09-06-2008, 11:45 PM
Direct, Print and Hold are the queue names that can be used. We generally use the Direct queue when setting them up.
