View Full Version : Bizhub c3850 broken scanner belt
mrfuser
12-12-2017, 10:20 PM
I have client did just move two of these machines to a new office and both of them have a broken Scanner. belt
Does anyone have a part number for the belt and how hard is it to replace
allan
12-13-2017, 12:24 AM
Just re-crimp and add glue to the joint. I fix that on the spot.
EarthKmTech
12-13-2017, 08:09 AM
Part number A121PP0N02
Piece of cake to change, keep one in stock.
Same belt used in c35, c3350 & c3850 variants. All versions snap the same way.
mrfuser
12-13-2017, 04:02 PM
Thanks all for the tips. Any idea why they break?
Woxner
12-13-2017, 08:41 PM
because when they moved them they slammed the scanner to one side most likey.
JR2ALTA
12-13-2017, 11:00 PM
Its not easy for me, I spent an hour chasing my tail the first time. There's a pdf in this thread to help
Konica Minolta bizhub C35 Scanner Belt Replacement. (http://www.copytechnet.com/forums/konica-minolta/110682-konica-minolta-bizhub-c35-scanner-belt-replacement.html)
EarthKmTech
12-18-2017, 12:07 PM
The belts snap always at the end where the belt is folded over itself to form a loop and is crimped. The brass crimp ends up cutting all the way through the belt. Crap belt design, clearly just an existing off the shelf belt being modified to suit a specific application instead of being designed from the ground up for the task.
B0265
12-18-2017, 03:55 PM
KOM160433
To improve the quality of the Scanner Belt in the Optical Unit, the following changes have been implemented
for the Caulking Parts and Tension Coil Spring of the Scanner Belt.
<Caulking Parts>
- Change the Material (Brass => SUS)
- Change the Tip Shape (Wave Shape => Flat)
- Width Change of the Caulking Parts (4mm => 6mm)
- Defines the hight of the Caulking Parts (2.9mm)
<Tension Coil Spring>
- Change the inner diameter of the hook part in the "inner diameter 5.55mm"
Due to the above changes, the Parts Number of the Scanner Belt has been changed
New Parts No.A121PP0N02
copyrooks
12-19-2017, 03:03 PM
Added the bulletin
EarthKmTech
12-20-2017, 06:59 AM
Aannnd, they still snap.
300+ of these in one customer, revised part number still breaks, regularly.
srvctec
12-21-2017, 04:57 PM
Yeah, it's just a crap design since the strands in the belt only go lengthwise (when they fail, there are always strands sticking out from the inside of the belt, like it just pulled apart, sliding on the strands). I think what would help is if they need to make them with X pattern strands inside the belt and then change the crimp.
mrfuser
12-27-2017, 06:14 PM
Thank you all for your tips! Great info to have. I ordered new belts, and before installing them I added a little dab of super glue gel to where the tabs are bent over the belt just to give it a little more strength. Seems to be working fine for the moment.
Take care all !
K
gitana1983
02-15-2018, 05:10 PM
KOM160433
<Caulking Parts>
Quick question, I have already replaced the belt but now is the scanner which is faulty but in the manual only shows the whole assembly, how can I get part number just for the scanner?
habik
02-15-2018, 05:23 PM
Quick question, I have already replaced the belt but now is the scanner which is faulty but in the manual only shows the whole assembly, how can I get part number just for the scanner?What codes are you getting?
Sent from portable device using fast cheapset!
mrfuser
02-15-2018, 05:28 PM
Start a new thread
