View Full Version : CS 2552ci How to open the toner door manually
COPYDOCAZ
12-16-2017, 07:46 PM
OK I know that the toner doors will not open automatically until they are empty, but I need to open one to remove a the toner to put in another machine, I know there is a manual method to open them but can,t remember how, also can't find the info in the Service manual.
Any help will be appreciated.
Mark
JR2ALTA
12-16-2017, 08:18 PM
Take magnet and slide it on up on the tinted black plastic window inside the toner door. You should hear a release.
Hose1cook
12-16-2017, 10:26 PM
Sim 159 > set the "Container Unlock Display" to on then open it in adjustment / maintenance in the system menu. Don't forget to turn it off if you don't want your customers to change toner prematurely.
Moshie
12-17-2017, 10:09 PM
On the webpage u can do it (I find it the best way)
Johny23
03-14-2018, 11:09 PM
Hello!
Can you give more info about finding this "Container Unlock Display". I tried to find it in webinterface, in system menu, but still didn't find it :(
And btw what is "Sim 159"? :rolleyes:
tonerleak
03-20-2018, 11:25 PM
Sim 159 is in the Maintenance Mode tables, should be easy enough to find if you have a service manual:confused:
Johny23
03-21-2018, 01:50 AM
Unfortunately I havn't got it. Hope I will find it somewhere for free, because I don't want to pay for it just for that little problem.
sparkycivic
03-21-2018, 10:34 PM
a strong magnet from a hard drive is very handy for opening these override covers. Especially magnets from multi-platter 3.5 inch drives.
aosboise
03-29-2021, 02:01 AM
1087 1087 ,159 start
I sure as heck hope that this toner cartridge has not been stuck in this machine for over three years!
Samanator
03-29-2021, 05:07 PM
I have attached the below as a text file. I made the text file so folks can remember how to do this without bothering me. :cool:
CS xxx2 - Open toner door
Put into Maintenance Mode: 10871087
>U159 - Set Toner Container Function
> Start
> Container Lock
> change EMPTY to OFF > Start
Open the top front cover to access any toner bottle.
When finished close all toner covers and then close the top front cover.
At this point do the following:
> change OFF to EMPTY > Start
> Stop > Stop
> input 001
> Start to exit Maintenance Mode
