View Full Version : Error Code Konica Minolta Bizhub C253 error C-DC00
Naveed Shahid
12-17-2017, 10:26 AM
Hello Everyone
Bizhub c253 Keep Showing C253 I Changed Already MFp Board But Still Same Error
Any Suggestion
Highly Appreciate
Synthohol
12-17-2017, 03:00 PM
did you run the latest FW? did you select engine data restore?
Naveed Shahid
12-17-2017, 03:03 PM
No Didn’t Upgrade Firmware and engine data restore badluck i dont have firmware 😒
kmcopytech
12-17-2017, 03:05 PM
Check:
1\coin vendor set.
2\Scanner connection.
3\Hdd.
Synthohol
12-17-2017, 03:39 PM
manual says security issue. did someone try to copy money even as a joke?
try formatting the HDD?
Naveed Shahid
12-17-2017, 04:37 PM
I try to format hdd cant be able format any suggestion
Synthohol
12-17-2017, 04:39 PM
if it cant format, replace it.
Naveed Shahid
12-17-2017, 04:42 PM
i replaced hdd from running machine but still same position
Synthohol
12-17-2017, 04:56 PM
ok, can you boot into service mode and do a data initialization?
Synthohol
12-17-2017, 04:59 PM
check your messages
cayyell
05-15-2018, 11:25 AM
Hi
any update regarding the issue? I m having the same code on C280
