View Full Version : C253 vs c353 iu and dv
mrfuser
12-19-2017, 04:32 PM
Does anyone know if a c253 and c353 use same iu and developer units?
copier addict
12-19-2017, 04:39 PM
They are keyed differently. You may be able to put a C353 chip on a C253 IU and vice versa. I have never tried it.
paulrid
12-19-2017, 04:57 PM
Only difference is the chip I've swapped many around.
copyman
12-19-2017, 06:11 PM
Most aftermarket reset chips are universal and fit both c253 & 353.
Same thing with aftermarket "toner" chips, they will fit both C253 & C353 toners but you have to modify the front cover to fit in the other model.
antone
12-20-2017, 04:53 PM
Does anyone know if a c253 and c353 use same iu and developer units?Not the same
Sent from my SM-N920V using Tapatalk
mrfuser
12-20-2017, 05:06 PM
Actually they are and worked fine just swapping chip
copyman
12-20-2017, 07:24 PM
I used to have around 100 of this series in my accounts and I swapped IU's from C253's to C353's and other way around all the time with just changing the chip. Never had an issue.
