View Full Version : Bizhub c454e bypass issues
n25an
01-05-2018, 10:00 PM
Paper type letter 100 lb white cover smooth...
The old rollers for bypass will not pull after 40 pages...
Wait a while print...
Then after 40 pages jams
Now the new rollers spin and spin...
I have isolated the issue to the big roller on top...
What I am checking is if there is a roller from another model that will work in the bypass
In the sharps... You can't use the recommended rollers...
It will jam
I am checking if there is a similar issue with the rollers for the Konica bypass...
The original roller that came with the machine works but jams intermittently
The new rollers just spin and can't get a grip...
The new rollers are the green translucent urethane rollers...
The old... Not sure... Checking here to find out...
Also the grey rollers don't work either...
It could be a matter if cleaning or greasing but not sure
Checking with the wisdom of the net...
n25an
01-05-2018, 10:01 PM
Bypass pulls plain paper...
Just not this paper...
Woxner
01-05-2018, 10:15 PM
the bypass roller is orange and sep roller is like a dark green or blue color. these pull 80lb no problem.
Synthohol
01-05-2018, 11:58 PM
specs are up to 24# plain paper on bypass, anything else is a gift.
n25an
01-06-2018, 12:55 AM
actually the machine is rated for 80 g/m2
to load it up...
but can use as high as 300 g/m2 in bypass
in lbs thats about 200 lb paper... in bypass
part used
A00F623201
so machine should be able to handle it...
anything else I can try...
any thing that I can use to make the roller sticky...
or work better...
any parts I can change...
n25an
01-06-2018, 01:31 AM
I took a look at the specs...
am I wrong...???
lb to g/m2 calculator
(http://bollorethinpapers.com/en/basic-calculators/basis-weight-gsm-calculator)
n25an
01-06-2018, 02:19 AM
checking the service manual found an adjustment... looks like this might be what I am looking for...
1.5.2 Paper jam for thick paper
there is a spring adjustment in this section...
that may be what I am looking for...
if anyone has tried this or something similar... let me know...
If that does not work... then I am going to change the whole bypass paper tray section...
thanks for giving a place to bounce ideas off
thanks again...
blackcat4866
01-06-2018, 02:36 AM
That's what you want right there. =^..^=
n25an
01-09-2018, 01:25 AM
The thick page adjustment for bypass worked with some caveats...
if I used the old paper feed top roller and bottom roller worked perfect with plain and thick paper...
if i use the new upper and lower paperfeed rollers... it jams towards the end... of a run with thick paper... I didn't bother to check what it did with plain paper...
AjitN
01-09-2018, 03:37 PM
If it is working OK with trays, It should work OK with bypass since bypass tray have better pulling capacity.
you need to check very carefully if that paper is suitable for our machine (if bypass is able to pull 300 gsm , so I think 90-100 GSM should not be a big issue.)
IF ROLLERS ARE WORNOUT CLEAN WITH diesel, ultimate cleaning solution.Need some time to evaporate, OR Clean with Moist cloth afterward.
It should work. OR There is some other Problem in paper feeding ( Motor, Gears, Clutch etc.)
