View Full Version : CQ TA 3050ci - Cyan only imaging issues
jqueen
01-08-2018, 06:50 PM
Going Crazy!!
Only happens with Cyan. Replaced DV and DR units and still does it. Cleaned charge rollers and replaced charge rollers and still does it. I'm reading that maybe a DV issue?? Please see attached file for what I am talking about.
In prints and copies - first 5, looks great. Afterwards, Cyan Streaks - Ahhhh!!:mad::confused:38560
Manual Doesn't help with this issue - Unless I'm blind....:o??
Billy Bob
01-08-2018, 07:50 PM
Going Crazy!!
we had similar issue only with magenta , ill find out what solved it when back to shop ,
Tonerkiller
01-08-2018, 08:13 PM
Looks like the dev unit is not getting toner, like it should
blackcat4866
01-08-2018, 11:57 PM
If the interval is 37.5mm it's primary charge. Perhaps your primary roller is not inserted completely or has a flat spot? Try swapping the primary with magenta and see what happens. You'll want MC-8720. =^..^=
tmaged
01-09-2018, 12:52 AM
Check the drum gound for Cyan on the toner hopper unit on the front of the machine. Usually problems that occur after a period of time are due to not being able to discharge voltage to ground properly.
jqueen
01-09-2018, 01:03 AM
I swapped out the charge roller with Yellow. Still the same.
And about the new charge rollers, yes, I have seen them for the 7551ci.... IT'S ABOUT DAM TIME!!! ;)
jqueen
01-09-2018, 01:06 AM
I will check that out. That makes sense...
And that is inside the toner hopper? Yes?
pascalb.
01-09-2018, 03:13 PM
Hello ,
I already had an identical problem.
on 20 copies the first ok after the background goes up.
it was the transfer belt.
to test.
blackcat4866
01-10-2018, 12:37 AM
This is what tmaged is talking about. When you see rust like this on the primary charge handle you know you're looking in the right place:
38568
It's very common for some techs to wipe off the black grease because it gets on your hands, but it really needs to be there. Apply the black conductive grease to the tips of all four drum shafts. The actual drum ground contact is in the toner hopper assy in the front:
3857038569
jqueen
01-15-2018, 08:15 PM
38568
3857038569
Nope. Didn't see that. However, I did check the Transfer belt and noticed that the cleaning unit discharge roller was peeling. So I replaced that and it came back. Just replaced the cyan dv/drum unit and waiting to hear if that was it. I've seen this before where the DV unit starts to act up. Its been a year since it has been replaced. So, we replaced it. Just waiting to see if I can close out the call. Thanks for all the help with this. You guys are awesome!!
