View Full Version : Biz hub 454e
antone
01-09-2018, 11:29 PM
Doc feeder 701 .. paper detection sensor not working ...changed sensor , document board.All the other sensors work..any 411 on this problem.
Sent from my SM-N920V using Tapatalk
allan
01-09-2018, 11:49 PM
What do you get. Original left on glass?
Check the ADF original set sensor...
Unplug the DF to check.
antone
01-10-2018, 12:48 AM
Unplug the DF to check.Allan...i hit start nothing happens...chk paper detection sensor not working
copier addict
01-10-2018, 03:24 PM
Have you gone into service mode and checked that DF-701 is selected?
Also make sure all three connectors are properly seated.
antone
01-10-2018, 04:24 PM
Also make sure all three connectors are properly seated.Yes .....did that asap
allan
01-10-2018, 04:50 PM
So if you open and close the DF cover the rollers lift?
antone
01-10-2018, 05:37 PM
So if you open and close the DF cover the rollers lift?Yes that's ok...insert doc...hit start ...rollers don't come down ect
