View Full Version : Biz hub 3850f
antone
01-10-2018, 05:54 PM
Error E301....did power reset...reset memory....anything 2 add?
Sent from my SM-N920V using Tapatalk
Synthohol
01-11-2018, 01:10 AM
from the service manual, does not even list relevant parts to replace!!
Trouble type
Trouble code
E301: Referring incorrect memory
E302: Incorrect command
E303: Finished due to error inside Qt library
E304: Finished due to error outside Qt library
E305: Program forced to stop
Rank
C
Detection timing
Received an error of irregularity.
Trouble isolation
Relevant electrical parts
(2) Procedure
1
Turn OFF the main power switch, disconnect and then
connect the power cord. Wait for 10 sec. or more after
connect the power cord, and turn ON the main power
switch.
2
If the above actions do not solve the problem, contact
KM.
antone
01-12-2018, 01:39 PM
Trouble type
Trouble code
Rank
C
Detection timing
Trouble isolation
(2) Procedure
1
switch.
2
KM.
Special firmware update...took care of trouble code
