View Full Version : Miscellaneous Bizhub C358 missing 'Device Comsumables' tab
copier tech
01-11-2018, 08:08 PM
Hi all, my question as in the title this tab is missing so no way to view image unit life, is it possible an engineer has disabled this somehow, a SW for example no mention in the CE manual
tech51
01-11-2018, 09:35 PM
This does not appear by default on the 8 range. There is a dip switch to enable it, but it requires an engineer to do the adjustment.
steve schofield
01-11-2018, 09:41 PM
Soft switch 227
hex 00
kenpio
01-11-2018, 09:53 PM
We have found this also. We looked through the manual and found that if DIP SW 227 and 230, all the bits are 0. That will make that consumables button appear. Go to switch 227 and change all to 0 and then hit FIX and the same for Switch 230. Hope this helps.
KEN
blackcat4866
01-11-2018, 11:10 PM
Good to know! Thanks! =^..^=
kingarthur
01-12-2018, 08:33 AM
there's a bulletin TAGB1700562EN about it, think it occurs after FW Function version 3.3,
copier tech
01-12-2018, 12:11 PM
Perfect thanks!
this site rocks lol
mascan42
02-21-2018, 12:02 AM
Why is it that the UK gets all the helpful bulletins and they're never published in the US?
EarthKmTech
02-21-2018, 05:50 AM
Every 8 series i goto that has this crap feature enabled I turn it off so the consumables page returns.
I also turn on near life display and consumables reminder for drums since they barely even last the standard life.
giddyupngo
02-22-2018, 04:13 PM
Thanks for this information. I would like to have the button "consumable life" because I like to look at the gas gauges during problem diagnosis. However I don't want a warning on the screen (but an oil can would be OK). From the manual it seems blanking 227 and 230 give you the button AND the warnings and life stops. Is this right?
copier tech
02-22-2018, 08:29 PM
You only need to change sw 277 to enable the comsumables button not sure what sw230 does.
rrrohan
02-23-2018, 02:28 PM
are we talking about the consumables page in Page Scope or under utility/counter ?
giddyupngo
02-23-2018, 03:12 PM
I'm looking for the one under utility/counter with the little bars representing life remaining, accessible on the operation panel.
copier tech
02-24-2018, 09:22 AM
Yes, so change sw 227 to HEX 00
Kenny
03-04-2021, 07:18 AM
Hi guys,
do you know the software switch to disable this consumable life reminder tab?
tsbservice
03-04-2021, 07:36 AM
Hi guys,
It is tab(Consumable Life Reminder) in System 2 menu.
