View Full Version : C6501 C2823 coding
methogod
01-12-2018, 09:11 PM
All supplies under 80%
swap drums, stays with CYAN.
Replaced Drum Potential Sensor and BOARD.
Replaced DV drive motors, assy as it seems like it was not
NO CHANGE
Stil codes C2823
Looking for a jedi in here to guide me...
Dropbox - 2018-01-12 15.50.25.jpg (https://www.dropbox.com/s/l6wryjjm45g7avm/2018-01-12%2015.50.25.jpg?dl=0)
copier psyco
01-12-2018, 09:34 PM
NO CHANGE
Stil codes C2823
Hi methogod ,
Check the humidity level inside the copier ,when it is very low the machine generate this code and the transfert on the paper is very bad. Had that issue many time during winter time at Montreal !May use humidifier next to machine and fixed the problem .
antonisp
01-13-2018, 06:49 AM
Good morning,
I guess you tried swapping coronas and checked for clean corona contacts etc...
Whats the measurement in between the lines on your sample?
I agree with psyco, humidity can cause charging errors, whats the humidity reading in the machine? [02 Process Adjustment]->[03 Sensor output check]->[06 Humidity/Temperature].
methogod
01-18-2018, 02:02 AM
humidity is under 20, cold here is maryland and its right near a outside door (glass).
But would think its in the window of konica range. Why only CYAN if its the humidity.
We just replaced high voltage board, i had a spare from a low meter parts machine. Lets see how it does...
I am ok with just ok color quality, as we run transactional color on it - have other machines for more higher quality work.
