I was setting up a new C308 in the office today. I initially turned it on and could only hear fans and such engage, no panel illumination etc. This ended up being the machine not liking the additional RAM that ships separate from the machine (don't know why it doesn't already come installed on the machine at this point). Anyway, I reinstalled the RAM and machine went to ready. I only mention the RAM issue incase this helps any of you guys with my bigger issue.
After setting up the machine as per the manual, I usually take my printed Management Lists and use these originals as test copies to test paper passage and finisher operation. The machine functioned fine; however I noticed that the copies looked blurry. When I would do 2 sided to 2 sided through the DF-704, the front side would have a few blurry spots around the text but the second side would have this plus it was also picking up the image from the front side and ghosting it on the second side. I was able to adjust the scanner light adjustment up to 3 for RGB and this would eliminate the blur on single sided documents. However, as soon as I ran 2 sided the issue was much worse on the second side.
Prints are fine, so I can pretty much eliminate that.
Scans look ok.
I've attached sample images of what it's doing. Perhaps you guys have seen this issue before.
The issue is most pronounced when making 2 sided to 2 sided copies. Most signs point to the DF-704; however, I still see some remnants of the issue off the glass. MFPB board?
Any help is appreciated.
Scans look ok.
