View Full Version : C353 Firmware Question
guitar9199
01-15-2018, 04:52 PM
Hey Troops,
Can anyone let me know what the newest/latest/greatest firmware version is for this model? I only have G00-R6 showing in my available list.
Thanks in advance,
Steve
copier addict
01-15-2018, 05:06 PM
G00-R6 is the most recent base firmware, however there are more recent special firmware versions
habik
01-16-2018, 01:01 AM
What issues is the machine experiencing?
Sent from my Mi A1 using Tapatalk
copier tech
01-16-2018, 07:33 AM
38607
copier addict
01-16-2018, 02:11 PM
[QUOTE=copier tech;590196]38607[/QUOTE
guitar9199 is in North America, the firmware you displayed looks like it is for the European market. G00-R6 is the latest base firmware here in NA
guitar9199
01-16-2018, 06:17 PM
Customer no longer able to scan to email using Office365. They're also a 100% Mac environment, so SMB scanning is not an option. My boss is working on upgrading the customer's machine, rather than have me configure FTP scanning on 12 Mac computers.
habik
01-16-2018, 06:31 PM
Have you tried creating new 365 account dedicated to the copier or using one of the users credentials?
Fully authenticated?
New certificate?
Admin and machine address has to be the same.
copier tech
01-16-2018, 08:08 PM
In a Mac enviroment I install a cheap basic Winsows PC on the network then simply set SMB scan to that the mac uses can access these folders.
Can pick up a basic PC for peanuts.
Synthohol
01-16-2018, 11:52 PM
Solution
CAUSE: Gmail™ server and Office 365™ server changed SSL certificate from SHA-1 to SHA-2. The MFP's do not support SHA-2 certificates and, therefore, fail to send E-mail if using the server as SMTP server. Even if using another SMTP server which has SHA-2 certificates for SSL, the MFP fails to send E-mail.
time to upgrade!!!
Synthohol
01-16-2018, 11:58 PM
SMB is an option, surprisingly simple.
Reference
Konica Minolta fully supports scan-to-email using Microsoft® Office 365™.
Microsoft® Office 365™ uses SHA-2 for its mandatory hashing cryptography algorithm.
In 2002, SHA-2 became the new recommended hashing standard. SHA-2 is often called the SHA-2 family of hashes because it contains many different-size hashes, including 224-, 256-, 384-, and 512-bit digests.Currently the most popular one is 256-bits
As of January 1, 2016, Microsoft will no longer allow certificate authorities in the Microsoft Root Certificate Program to issue certificates for SSL or code signing that use the SHA-1 hashing algorithm. SHA-2 is the preferred method now.
The following are the incoming and outgoing IMAP server settings for Office 365.
Setting IMAP (incoming) SMTP (outgoing)
Server Name outlook.office365.com smtp.office365.com
Port Number 993 587
Encryption Method SSL TLS
the "3" series never even made the cut.
Supported Models:
bizhub 224e/284e/364e/454e/554e
bizhub 654e/754e/
bizhub C224e/C284e/C364e
bizhub C454e_C554e
bizhub C654e_C754e
bizhub 227/287
bizhub C258/C308/C368
bizhub C458/C558/C658
bizhub 808/958
bizhub 4050/4750
bizhub C3350/C3850/C3850FS
bizhub C220/C280/C360
mincopier
01-17-2018, 01:55 AM
Could try GMX mail. They have free accounts and setup is fairly easy. Once logged in you must go into the email security to allow the use of Outlook and Thunderbird so that email will work. Uses port 587 and SSL.
JR2ALTA
01-17-2018, 02:27 AM
You should consider a NAS device
bogandof
01-25-2019, 10:46 AM
Bonjour tout le monde
Je suis un technicien en informatique et nouvelle technicien de machine a photocopie
J’ai un problème avec une machine konica minolta bizhub c353 elle démarier mais elle plante la sablier sur le panneau et je essai de change les barrettes mémoire et rien a changer, je contacte un technicien il ma dit que j’ai un problème avec NVRAM, et je ne sais pas comment je fair pour télécharger le microprogrammes et comment faire pour installer sur la machine ( y pas des porte usb sur c353 )
imad.zemmouri@gmail.com
bogandof
01-25-2019, 10:47 AM
Hello everyone
I am a computer technician and a new photocopy machine technician
I have a problem with a machine konica minolta bizhub c353 it starts but it crashes the hourglass on the panel and I try to change the memory modules and nothing to change, I contact a technician he told me that I have a problem with NVRAM , and I do not know how I do to download the firmware and how to install on the machine (not usb door on c353)
LindseySarvis
04-13-2019, 11:04 PM
Are there resumes on this point of view?
copier tech
04-14-2019, 10:10 AM
Hello everyone
To upload the firmware on this old machine you need a compact flash card, to load firmware onto the card you use the firmware imaging toolkit (This installs on your laptop)
Personally i’d suggest to your client they upgrade.
LindseySarvis
05-09-2019, 12:10 AM
Há tantas perguntas relacionadas ao tópico mencionado. E qual é o melhor aspecto e onde encontrar tcc pronto (https://olatcc.com.br/) para trabalhar com isso? Certamente, o aspecto principal está conectado aqui.
bogandof
06-19-2019, 08:26 AM
hello thank you good copy tech for your answer, yes I have 2 CF card 128 MB and 256 MB and I have the software image tool kit, I need firmware for this machine c353, and thank you another copy tech
