View Full Version : CF2002 with Error 3C50
jmandassociates
09-10-2008, 08:38 PM
Can somebody help with a CF2002 with a 3C50 error
cobiray
09-10-2008, 10:07 PM
I don't see that error code in the troubleshooting section of the manual. Usually the codes are Cxxxx (i.e. C0500). Did you mis type the code maybe?
Darren King
09-11-2008, 01:44 PM
8020/CF2002/8031/CF3102
�� Codes C-3C00 through C-3C40 indicate a corrupt BRU
�� Codes C-3C50 through C-3C90 indicates a problem with the PWB-C board or the scanner to
main body cable
lvangsnes
09-11-2008, 05:07 PM
Darren is correct. I have been able to just clear the code and the machine will run fine for several weeks after. My customer doesn't want to buy a C board...they are kind of pricey for an older machine.
B0265
09-11-2008, 08:42 PM
Add an electrolysis capacitor (100 microfarad) to C143 in parallel on the PWB-C .
Solder the capacitor on the existing C143.
Capcitors recommended by KonicaMinolta:
- UVR1C101MDD1TD(Nichicon)
- ECA1CM101(Matsushita electronics)
- RE3-16V101M(Elna)
- 16YK100M(Rubycon)
williama
09-26-2008, 07:24 AM
lvangsnes
How did you clear the code?
B0265
09-26-2008, 07:35 AM
Press the reset switch inside the front cover.
williama
09-30-2008, 06:17 AM
thank you for your help - machine is running great
john123
10-07-2008, 06:39 AM
Hi, I recently bought a copier cf2002, it was saying to replace image units red and blue, did that and it works but soon after yellow image came up too, replace it and keep saying same msg to install the yellow image?
any help would be much appreciated...
Thnx
dfussell
11-06-2009, 08:11 PM
I work at Mobile Area Water and Sewer company. We have a Imagistics Color Copier that keeps coming up with the same problem.
C-3c50
The only way for the machine to continue is to open and close the front door and shut machine off then turn back on.
This happens everyday and takes even more effort on a following Monday after a weekend.
Any suggestions would be greatly appreciated.
B0265
11-07-2009, 09:53 AM
- RE3-16V101M(Elna)
- 16YK100M(Rubycon)
Did you read all posts?
