View Full Version : Electrical Bizhub 654e ,two strips on the touch panel after switching on.
pinspin
01-18-2018, 04:52 PM
Hello .After a power failure, the copier stopped functioning properly. After turning on two bands appear on the touch panel . We tried to replace all logic boards, but without result. The MFP board firmware update ends with a message = Not good = . We will be grateful for any advice.
allan
01-18-2018, 05:42 PM
Does the machine restart by its self?
So it does get to the firmware upgrade menu?
Woxner
01-18-2018, 09:04 PM
when doing firmware load one file at a time. its pain but it should go. i have seen certain levels stop with this message if bizhub secure is done or sometimes the flash drives make a difference. but do try one at a time
pinspin
01-22-2018, 01:53 PM
The machine does not restart and does get to firmware upgrade menu.
Rvale
01-22-2018, 03:46 PM
I have seen that before, when you update from some firmware versions you have to update the display as well, it's a different method but does the trick.
pinspin
01-23-2018, 02:52 PM
After Firmware Update we we get a message
= Error. This is invalid External Memory . Please make sure the External Memory =
= MFP Comtroller Download N.G. ( ADF , Scanner , Printer Download Completed ) =
jamesyboy
01-23-2018, 04:14 PM
sounds like the sd board is cattle trucked
pinspin
02-02-2018, 01:23 PM
We replaced MFP board and NVRAM card - the copier is functioning normally .
