View Full Version : opc drum counter how to reset
itwasntmhee
09-11-2008, 03:15 AM
unit: Konica Minolta CSpro Ep2030
problem: opc drum Counter (RESETTING 'REPLACE DRUM' MESSAGE)
lvangsnes
09-11-2008, 05:04 PM
Enter service mode, touch 8(parts life counter) then start, then press 2 (pc life counter) press clear. The drum, developer, and blade counts will all zero out if you run an F8 also.
itwasntmhee
09-12-2008, 01:47 AM
thanks..
can you give me the exact steps?
im sorry because im not a technician...
thanks in advance..
lvangsnes
09-12-2008, 01:53 AM
To enter service mode:
touch METER COUNT then
STOP ZERO ZERO STOP ZERO ONE
this is service mode. the easiest way for you would be to remove your toner bottle, then touch ONE the screen will say F then touch 8 and press start and the machine will do an ATDC adjustment. When it finishes, touch panel reset twice to return to user mode, and put your toner bottle back in. YOU MUST REMOVE YOUR TONER BOTTLE BEFORE YOU RUN THE ADJUSTMENT.
If this doesn't clear your message, then enter service mode and do the steps in the previous post.
Scott_Lewis
09-12-2008, 07:07 AM
Darn, I never knew that. Always zeroed the port counter prior to F8. Or is my memory failing me and the 2030 was fancier/more advanced than the 2050?
lvangsnes
09-13-2008, 12:22 AM
The 2030 is a newer machine than the 2050. I did like the 2050 for its copy quality, but its older siblings were really junk as far as the d/u
itwasntmhee
09-15-2008, 02:10 AM
thanks...but not work for me...
lvangsnes
09-18-2008, 09:25 PM
Everything you need is there.
anjali
10-18-2008, 06:13 PM
How to stop counter of KONIKA MINOLTA BIZHUB C252
minimerlin
10-18-2008, 07:37 PM
Turn off the copier! Or don`t make any copies!! Why do you want to stop the counter?
Scott_Lewis
10-19-2008, 02:15 AM
Trying to get out of paying your per copy charges, are ye?
This could be somewhat like stealing. Fraud comes to mind......
